Ir para o conteúdo principal
The Asus X551M-RLN03 is part of the Asus X-series. It is a 15.6 in notebook that runs on Windows 8 with an Intel Core Processor.
7 Perguntas Visualizar todos
Laptop has a shortage
I tried to plug in my headphones and touched another port. As soon as the metal tip touched the other Port my computer turned off immediately and will not turn back on. No power buttons are on. Is this an expensive fix or something I can do.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@stacyedwards depends on what other port you touched and which part got shorted out. you will at minimum need to look at it. Check the motherboard for any obviously damaged components etc. Then you need to identify the motherboard. There will usually be a maker and model number silkscreened on the motherboard. Let us know what you find on that. You cdan always add images to your QUESTION in case you get stcuk or have further questions etc. Adicionar imagens a uma pergunta já existente
Use this guide to at least get into your laptop. Asus X5511M-RCLN03 Battery Replacement
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Asus X5511M-RCLN03 Battery
Guia
Fácil
2 - 8 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Stacy Edwards será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 35
