Ir para o conteúdo principal
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Text but not call out.
The signal strength in my area is not strong enough to make calls. The phone works fine when a decent signal is present. I’m OK with this for now since I have a landline. I can, however, send texts when I’m in this low signal area. How is it I can send texts but not make a call?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
[ SMS is a standardized communication protocol that enables devices to exchange short text messages and was defined as part of the 1985 GSM protocol. Originally it was designed to "fit in between" existing signalling protocols which is why SMS length is limited to 160 seven-bit characters. It was subsequently codified into the SMPP signalling protocol that transmits SMS and is limited to precisely 140 bytes (or 1120 bits). ]
You need less that a second of stable signal to send one SMS, but one call needs a stable connection to start a session.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you...
por
Adicionar a sua resposta
ruko será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 160
