How to Upgrade Memory Ram?
How to Upgrade Memory Ram ????
Esta é uma boa pergunta?
You can’t! The RAM is soldered to the logic board. But! You could replace the logic board with one which has more RAM. But there is a limit here! 16 GB is the largest you can go with MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.2 GHz 16 GB RAM Logic Board and MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement
Produto
$349.99
Esta resposta foi útil?
Ok there is two ways 1 is to do as suggested and buy a board with 16gb already installed that is much easier the long answer is you can although you would have to buy a solider reworks station and out source 4 ram chips for your particular model unsolder the existing ones with flux reball the new ones solder them on in the correct direction seal it up and pray that it works if somebody that is unskilled in soldering attempts there is no guarantee that it will work really it is a gamble so it might be worth the 8gb that is already in your system to just stay in there.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 4,422
