Ir para o conteúdo principal
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
20 Perguntas Visualizar todos
vw car gets stuck in park
shift lever will not move out of park.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
4 liter v8 engine starts stuck in park, I can not back out of garage, help.
por
Does anyone know about what this would cost to fix by volkswagen dealership service
por
@caroldaly
Quickest way to know is contact a dealer in your location.
This is a world wide forum and since your location is not known the answer may not be relevant to your location.
por
Adicionar um comentário
1 resposta
Solução escolhida
Most common cause of this is broken or stuck shift safety latch. There’s a lock mechanism that prevents you from shifting out of Park until you press on the brake pedal. That lock mechanism can get stuck or broken and then you can’t shift out of Park. The fix usually involves accessing the shift lever mechanism or in some cases repairing the brake pedal switch. In rare cases, it’s an ECU reflash but usually it’s a mechanical switch failure.
Esta resposta foi útil?
Pontuação 1
2 comentários:
where are these switches and what is an ECU? and thank you for the help
por
The shift lock mechanism has 2 parts: a mechanical lock under the center console attached to the shift mechanism; and an electronic switch at the brake pedal up under the dash. The whole system is controlled by the car's main computer (called Electronic Control Unit, or ECU). I'm not sure where the ECU is on your Passat, but it's probably up under the dash, in the center console, or under one of the front seats. You can check the integrity of the brake pedal switch and shift lever lock mechanism, but ECU problems require a professional with specialized equipment.
por
Adicionar a sua resposta
Robert Lee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 3,406
