Ir para o conteúdo principal
A atualização de abril de 2014 do MacBook Air de 13" da Apple apresenta processadores dual core i5 e i7 renovados, além de um ligeiro aumento na autonomia da bateria.
Hall effect sensor - screen closed
Hi,
I have just been replacing my screen but the hall effect (sensor that detects the close of the screen to put in sleep mode) is not working anymore. I have found that this sensor is on the I/O board but I do not know where and how I can fix it. Thanks,
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
What part did you replace exactly, the screen assembly ? The hall sensor connects to the I/O board and it’s on the topcase, but it needs the magnet on the lid to be working properly. Unless the sensor was damaged somehow the only reasonable alternative explanation is that your replacement screen is missing the magnet. If you have a magnet around it will be quite easy to verify which of the two fits your case.
Esta resposta foi útil?
Pontuação 1
If you replaced the display you might have dislodged the magnet held in the lid frame, or the hall sensor is bad
Imagem
Using a rare earth magnet slide it across the uppercase where the sensor is located you should see the display turn on and off as you pass it across the sensor. Use a piece of tape to mark the location and now using a steel paperclip locate the magnet in the lid and marking its location the two marked locations should meet up. If not you either got the wrong lid assembly or the magnet is missing or got placed in the wrong hollow when you replaced the LCD panel.
Pontuação 1
Adicionar a sua resposta
Pierre-Luc Vérité será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 643
