Ir para o conteúdo principal
Modelo A1990 / EMC 3359. Lançado em maio de 2019 com novas opções de processador de 6 e 8 núcleos.
MacBook stuck on black screen
About a month ago my 2019 MacBook Pro was stuck on a blank screen.
It’s like the laptop was still working, but the screen stopped working. There would be a sound when I plugged the charger in, I could hear the fans working, I could even charge my phone. But the screen stayed black.
Eventually I found a fix online. I reset something by holding keys down after pressing the power button and it started working again.
Anyways, this exact same thing has happened (black screen), but I’ve forgotten what I reset to make it work again.
Can anyone suggest what I could try?
It wasn’t the SMC or PRAM/NVRAM. It was another one which I found only after hours of searching.
Any help would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi Josh. I am facing the same problem, did you find a fix?
por
Adicionar um comentário
1 resposta
Does an external monitor work?
The only other keyboard command is toggling AirPay on/off via the TouchBar AirPlay button or in the displays menu bar.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Josh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 1,725
