Why is my TV malfunctioning?
My TV started displaying different functions by changing the colour mode, volume etc
Esta é uma boa pergunta?
Hello Badejo
If nothing helps as described in the comments, try the following:
1) Unplug from the wall socket, wait 10 minutes, plug it back into the socket.
2) If this does not help, reset the TV to factory settings (see user manual).
3) If this still doesn't help, consult the service manual.
Good luck,;
Homer82
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 243
Can you post a short vid (or pics) of what you are seeing Adicionar imagens a uma pergunta já existente
por DanJ
Hi,
Try removing the batteries from the remote control unit and check if the problem is still there or not.
If it stops then there is a problem with the remote
por jayeff
