Ir para o conteúdo principal
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 Perguntas Visualizar todos
Why dont my brake light/turn signals work on 1995 gmc sierra 1500?
My reverse lights, brake lightand turn signals do not work. Running lights do. My 3rd brake light(on the cab) does work though. Fuses are good, relay seems good, new tail light bulbs and circuit boards still no fix.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi,
Just wondering if your hazard lights work at all?
por
Id recommend checking the grounds. Did you switch to LED or stayed with bulbs?
por
Stayed with regular bulbs and hazards do not work
por
Adicionar um comentário
2 respostas
Id try the grounds remove and clean til u get bare metal even if they look ok. Try reinstall. Any recent work or damage to rear or bed of truck. Perhaps a nicked or overlooked connection.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No wrecks or damage behind the front cap. Ive checked grounds and followed the wires to the brake petal switch aand everything looks good. I thought maybe the brake switch went bad but the. 3rd cab brake light still works so it doesnt make sense to me
por
Check your ground wires by rear bulb sockets. Remove grounds clean contacts with light sanding replace. Try relay to. May seem good but is not. Swap relays around. Must be equivalent size ok ?
Pontuação 0
Adicionar a sua resposta
mdillard111 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 43
Duração total: 1,727
