Ir para o conteúdo principal
Released in July 1983 in Japan, the Nintendo Family Computer, or Famicom, is the matching predecessor to the Nintendo Entertainment System (NES). Model HVC-001.
10 Perguntas Visualizar todos
correct ac power adapters
i have an ac adapter but it seems to be for the super famicom not the original famicom. it fits into the snes but not the nes either. i do not believe i am getting any power to the unit. also not sure of the exact hookup for it to the tv.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Here is what I found AC adapter for Family Computer(HVC-001) and Super Famicom(SHVC-001/SHVC-101). Moreover, It can be used by VirtualBoy(VUE-001) via AC adapter-tap. Input: AC100V 50/60Hz 18VA, Output: DC10V 850mA center minus (+-@--) Hope that somehow clears it up. You might need a multimeter to see if you are getting power from your AC adapter.I also attached to diagram for the PCB
Good Luck
Esta resposta foi útil?
Pontuação 1
I have exactly the same console (famiclone) and a megadrive 1 psu works fine...Thats the 1 with the silver end and NOT the yellow end..I hope this helps....
Pontuação 1
I have a pair of Famicoms (both the original and an AV Famicom). They both happily accept the power adapter from either a US Sega Master System, or a model 1 Sega Genesis. This PSU has the correct barrel connector size, voltage, and pin orientation.
Pontuação 1
Adicionar a sua resposta
nan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 28
Duração total: 5,204
