Replace series 2 to a series 3 case?
Hi,
Can I change my Apple Watch 42 mm series 2 case, with one from series 3? Will it work?
Mine looks very bad and can’t find at all, only other series…
Thank You
Esta é uma boa pergunta?
Hi,
Thank You
While it might be possible, its a fair amount of work! You will need to fully strip down your watch and transfer all of the part over. Just doing this is risky! As you are likely to damage something. Given the price of a new Apple Watch 3 is so low and offers much more performance. I would just get a new watch!
Now, if you had one of the special Apple Watch Edition (real gold! Yellow Gold or Rose Gold; Black, Grey or White ceramic) and wanted to put in the newer guts into it then I could see that as being worth it! Some of these cases are $20k
Esta resposta foi útil?
Thanks for your answer Dan, I will think about it.
@fullspy - I just spied this on 9to5 check it out! Apple Watch should be on every wrist after $129 Black Friday special
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 89
