Ir para o conteúdo principal
Replace SSD--Same as last year's model?
Can you replace the SSD in the 11" MBA (mid 2011) the same way you replace the SSD in the last 11" model?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I think it comes apart the same and uses the same SSD
All Apple did was bump the specs up
Esta resposta foi útil?
Pontuação 0
I'm not sure this is always the case.
I tried moving this hard drive from a Late 2010 13" Late 2010 MBA into a 2011 13" MBA and all I could ever see was the "No" sign.
- Jeff
Capacity: 251 GB (251,000,193,024 bytes)
Model: APPLE SSD SM256C
Revision: AXM09A1Q
Serial Number: S0N8NEAB127960
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Medium Type: Solid State
TRIM Support: Yes
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
disk0s1:
Capacity: 209.7 MB (209,715,200 bytes)
BSD Name: disk0s1
Content: EFI
jeffme hd:
Capacity: 209.48 GB (209,484,214,272 bytes)
Available: 139.14 GB (139,138,199,552 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s2
Mount Point: /
Content: Apple_HFS
Recovery HD:
Capacity: 650 MB (650,006,528 bytes)
BSD Name: disk0s3
Content: Apple_Boot
BOOTCAMP:
Capacity: 40.52 GB (40,521,998,336 bytes)
Available: 18.29 GB (18,286,682,112 bytes)
Writable: No
File System: NTFS
BSD Name: disk0s4
Mount Point: /Volumes/BOOTCAMP
Content: Microsoft Basic Data
Pontuação 0
Ok - please scratch my doubt, listed above. With further research, the SSDs in the 2011 MBAs are the same as in the Late 2010 MBAs - the Samsung AXM09A1Q.
The resolution to my problem was identified by a poster in another forum - apparently, you must, must, must format / reinstall the OS on the new machine via the Lion Internet Recovery function (cmd+option+r at the chime). This involves creating a Lion Internet install USB recovery key before going through this process.
Pontuação 0
Adicionar a sua resposta
Scott McDonald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 3,652
