Ir para o conteúdo principal
O Cruzer Blade é um pendrive USB 2.0 lançado pela SanDisk.
Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
Esta é uma boa pergunta?
Pontuação 24
2 comentários
Have you attempted to use any kind of write protection removal or partitioning tools?
por Compartilhar
usb write protected problem
por Compartilhar
Adicionar um comentário
5 respostas
Pergunta mais útil
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
Esta resposta foi útil?
Pontuação 4
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
Pontuação 3
1 comentário:
Is This One Really Working?
por Compartilhar
Sadly there just isn’t any way to salvage your USB drive.
Pontuação 1
Possible causes of read-only mount:
  • Security configurations on the Operating System; Too many to list, but they are altered using Windows Registry; Google around;
  • Corrupt Filesystem / Dirty Bit set; Use chkdsk;
  • Corrupt partition table; Use a drive partitioning utility; Pendrive will be erased but will be usable later;
  • Pen drive microcontroller reporting faults; It means it’s time to buy a new drive. I’m still looking into possible temporary fixes to make the drive last a few more days, but it looks bad.
Pontuação 0
1 comentário:
por Compartilhar
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
Pontuação 0
Adicionar a sua resposta
Rohit Dharan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 65
Ao todo: 6,399
