Ir para o conteúdo principal
A Ford F-150 2009-2014 foi apresentada no ano modelo 2009 como uma atualização da plataforma de caminhonetes de tamanho grande da Ford.
Power windows stopped working
I have a 2012 F250. The windows stopped working unless I open the driver’s door, and move it back and forth till I find a spot where the window switch will work. I had replaced the switch before I found that I could use the windows if I opened the door.
I took off door panel today and moved around the wires because I could not get windows to move even with the door open. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
The wire is not broken in the door, its broken in the hinge area between the door and the body of the vehicle, peel back the rubber boot covering the harness and fix the wire there.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I took it apart, but didn’t see an obvious broken wire. However, I was able to wiggle the bundle around and got the window up. Is there any way to know which wire might be broken?
por Compartilhar
If you have a volt meter, put the black wire on ground, put the red wire on one of the wires at the window motor connector, should be 2 wires. When you want the window to go up, one of the wires will be 12 volts, when you want the motor to go down, the other wire will be 12 volts. I will think that neither wire will be 12 volts when you push up or down, keep your red meter lead there while pushing the button, wiggle the wires until you get power on one of the wires, you found the wire, trace the break. worse case, you only need to trace the 2 window motor wires. Maybe the connector itself is corroded. Put your red lead into the back side of the connector to test it.
por Compartilhar
your harness wires between the door and post in the rubber tube are likely broken that power the front window
Pontuação 0
Adicionar a sua resposta
jtpd333 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 55
Ao todo: 6,419
