Ir para o conteúdo principal
Lançado em março de 2017, identificado pelo número de modelo SM-J727
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
Esta resposta foi útil?
Pontuação 0
12 comentários:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
por
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
por
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
por
Hope this helps
por
Yes if you have a computer
por
Exibir mais 7 comentários
Adicionar a sua resposta
Corbin Dallas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 1,943
