Ir para o conteúdo principal
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
My charger won't reach all of the way in.
Hello. I am having a hard time with my JBL flip 4 speaker where the charger won't go all the way into the charging port. It seems to enter to about ¾’s of the way in before stopping
When try wiggling it it seems loose. Everything is plugged in and the wire seems to be working fine with my headphones
Can anyone help? I'd hate to see my $180 speaker go to waste. Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @barackaflocka ,
Use a strong light and a magnifying glass to visually inspect the charge port enclosure for any obstructions or perhaps damaged connector pins.
If the port appears to be OK or even if you can’t tell, here’s a link to the ifixit JBL Flip 4 USB Port Replacement guide which should be of some help in accessing the USB port to check if it is connected securely or if you have to replace it
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Liam Ruggieri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 1,983
