Ir para o conteúdo principal
Turn signals, windows, door locks, tailgate, high beam
I just have new headlights, bumper and hood installed on my 2014 Sorento. Now my turn signals, power windows, power door locks, tailgate, high beams, and headlights have to be turned on manually… what is going on?! Is there a ground that supports all of this ?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
@truax031502 by manually I assume you are saying you have to use the switch whereas before those come on by itself?
por
Yes that is correct, it has an option where the lights will come on by itself or you can twist the knob and turn them on.
por
@truax031502 did you make sure the option is turned on
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@truax031502 make sure that you have the Auto light position turned on.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
David Truax será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 302
