Ir para o conteúdo principal
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
Fix a bent corner
What tool would you use to fix a bent corner on iPod touch 6th generation?
i have to replace the screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There are many professional tools that will make the corner look perfect, such as the gTool iCorner or the PlierTek Corner repair pliers. If you’re doing this repair as a one-off, then any type of small smooth pliers (Like this one) will help bend the corner into the correct shape.
You should be able to get a basic pliers set at any local hardware or craft store.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lunatixs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 163
