Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Digitizer replacement on S3
Hi guys
do the s3 non cellular and s3 cellular share the same digitizer as I have a broken screen on my s3 cellular and have a new S3 non cellular I can take the digitizer off to put on me s3 cellular
thanks
Kev
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Ok thanks a lot for that it’s very helpful
por
Adicionar um comentário
1 resposta
Solução escolhida
First you don’t want to replace the digitizer alone! All you do is kill the display part. The full display assembly needs to be replaced. Follow this guide Apple Watch Series 3 Screen Replacement You’ll find the needed part within the guide and no you need to stick with the correct unit.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kevmort será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 127
