Ir para o conteúdo principal
O Apple Magic Mouse é um mouse multi-touch fabricado e vendido pela Apple Inc. Ele foi anunciado e vendido pela primeira vez em 20 de outubro de 2009.
Can I replace the laser bulb?
Everything is working on my Magic Mouse but the laser sensor, itself. I can gesture, scroll, right click, double-click to select a word. BUT the laser no longer comes on, so I can't move the pointer. Can I replace the laser?
Esta é uma boa pergunta?
Pontuação 8
1 comentário
can you explain me in detail that how you fixed it kaath9?
por
Adicionar um comentário
2 respostas
Solução escolhida
I've never seen this part fail. I would suspect a failed solder joint. Of course if it is less than a year old, get a warranty replacement from Apple. If not, I'd tear it down and see if I could spot the problem. Here's the teardown: Desmontagem do Magic Mouse
Esta resposta foi útil?
Pontuação 4
5 comentários:
You're right mayer, mine wasn't working well, only clicks and movements but no cursor moving. Once opened, I've heater the laser pinouts with a soldering iron and it's working well now. The problem now is to fix the batteries plugs. In order to disassemble properly, we need to cut 2 plastic pieces who maintain the metallic rounded batteries plugs on the frame
por
Can I solder without removing the capacitive sensor ribbon nor the battery case? @kospeia Did you achieve to do it?
por
What Part of the mouse do you solder once you open it up?
por
Asher Solder the place where you no longer have continuity.
por
Thanks Mayer
por
I had the same problem! After several attempts, I tried to push the lens with a pencil eraser, now it works fine
Pontuação 0
3 comentários:
It makes me laugh, this is ifixit.
por
Hello fabrizio,
Did you just press it up, without opening the mouse?
Thanks in advance!
por
Hello Antonio, yes, you can do it without opening..... but ... the operation did not last much for me :-(
I think at this point that you have to open it and solder contacts with a soldering iron!
por
Adicionar a sua resposta
kaath9 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 33
Ao todo: 17,586
