Ir para o conteúdo principal
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4 Perguntas Visualizar todos
The brush rotates intermitantly, seems as if there is a loose wire
The suction is fine but, the roller brush rotates intermittently. It re-engages when I bounce the LiNX but not always when I turn it on and off. There seems to be a loose wire or connection somewhere. Any suggestions will be most welcome.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
I had a similar problem. However, my wire was severed. I had to open up the head unit and resolder it back together. Since that fix I have not had any issues.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Was the problem intermitent? Weems a severed wire would make it not work at all?
por
Yes mine works intermittent too, not sure what is causing this.
por
Adicionar a sua resposta
Alan McDonald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 460
