A button not working
A button not workimg
Esta é uma boa pergunta?
If you have only just noticed some stickiness or you’ve just spilled something on your controller, you only need a minor cleaning around your buttons. Grab some Q-tips and some rubbing alcohol for this quick cleaning tutorial.
Rubbing alcohol evaporates quickly and you shouldn’t be using enough to do any damage to the circuitry inside the controller. Never clean a controller with water as it can get inside and cause corrosion and circuitry damage to the controller.
Lewis
Esta resposta foi útil?
Great.. Its working!!
Thank a lot
can you mark it as an answer? Thanks.
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Ao todo: 2,027
1 comentário
My steelseries nimbus button “B” not working
por Taufiq Compartilhar
