Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
iPhone X boot loop issue
I am a technician with the skills and access to microsoldering equipment. I am trying to avoid separating the two board layers if possible because it is a pain to get back together and may not be necessary. The phone is doing a 3 second boot loop. I have tried to turn it on with only essential components plugged and I have frankensteined new hardware in order to rule out hardware issues. It is recognized by iTunes. I attempted every reset possible, and none of them work. When attempting to restore the iPhone through iTunes, the restore stops right after extracting software (likely because of whatever is causing the boot loop). On the board level, are there any pads I can test in order to confirm that I need to split the boards? Does anyone have a clue what might be causing the issue? On my USB detector, the output reads a stagnant 0.47A @ 5.09V
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Mine does exactly the same thing on trying to restore
por
Adicionar um comentário
2 respostas
Solução escolhida
Check around nand for shorts. But the problem could be the solder joints.
Esta resposta foi útil?
Pontuação 1
Try a genuine replacement charge port assembly. They can cause reboots when they go faulty.
Pontuação 1
Adicionar a sua resposta
Batteries Bulbs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 191
