Ir para o conteúdo principal
A a7R II (número do modelo ILCE‑7RM2) é a revisão de 2015 da Sony para a sua câmera mirrorless full-frame de lentes intercambiáveis.
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
Esta é uma boa pergunta?
Pontuação 0
5 comentários
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
por Compartilhar
Same problem. Any help?
por Compartilhar
Me too. Anyone sort it?
por Compartilhar
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
por Compartilhar
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
Esta resposta foi útil?
Pontuação 2
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
Pontuação 1
Adicionar a sua resposta
shaikly_17 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 1,749
