Ir para o conteúdo principal
Processador Core Solo de 1,5, Core Duo de 1,66 ou 1,83, ou Core 2 Duo de 1,83 ou 2 GHz. Isto cobre os primeiros modelos de Mac mini baseados em Intel, de início de 2006 a meados de 2007.
Replace Optical Drive with SSD
Is it possible to replace the optical drive in a mac mini A1176 with an SSD? The interface of the optical drive is listed as pata, but looks to be a 50-pin connector supplying power as well. Whatever that interface is, I'm looking for a sata ribbon adaptor for it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
The left hand column on this link to OWC shows upgrades for your machine including a SSD drive: http://eshop.macsales.com/shop/mac-mini/
Esta resposta foi útil?
Pontuação 2
2 comentários:
mayer,
the ssd upgrade on that link appears to replace the existing hd in the mini. I'm looking to replace the optical drive with another ssd.
por
You are correct, it uses a PATA connection, and in order to use a modern (half decent) drive, you would need to convert the connection from a PATA to a SATA drive. Of course these are still IDE connections, just different interfaces given the project.
A convertor like this would work: http://firmtek.stores.yahoo.net/seritek1...
The issue is then compatibility. To be honest, I know that Apple has never truly supported PATA to SATA connections, but that doesn't mean that it won't work.
Pontuação 0
1 comentário:
knowitall,
thanks. ive ordered a similar circuit card based adapter from amazon, waiting for it to arrive. im hoping for a cable solution, but no luck so far. goal is to fit the whole bundle back within the mac mini case.
por
Adicionar a sua resposta
paul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 4,915
