Ir para o conteúdo principal
Lançado em novembro de 2018 como uma edição da linha Pro do iPad. Modelo A1980.
Where to source replacement LCD
Hey there, I’m trying to figure out where to source quality trusted lcd for this Ipad. From what I’ve gathered Ifixit and InjuredGadget a two such options. However one is quite high in the price and the other is out of stock, is there anywhere else trusted among the folks here for quality parts?
Thank you
Esta é uma boa pergunta?
Pontuação 4
1 comentário
try ebay and aliexpress
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Hi @proffesir_snape
I have used a lot of mobile sentrix premium parts in the past and been happy with the level of quality. In many cases the parts have been OEM quality. They would be the only source I would trust for this repair.
Unfortunately they are out of stock of your part right, but in case they get it soon here is a link for you to check out:
https://www.mobilesentrix.com/lcd-assemb...
Hope this helps!
Esta resposta foi útil?
Pontuação 2
1 comentário:
thank you so much. coincidentally I just bookmarked that very same one along with a few others only a few minutes before you commented.
por
Hello! I would strongly suggest PREMIUM GRADE lcd assembly for iPad Pro,11 and 10.5. Refrain using generic grade as you may experience booting or charging issues with such part grade.
I have been using Mobile Sentrics and Injured Gadgets Premium Grade Parts for the above mentioned IPad Model repairs and strongly recommend.
Pontuação 1
Aliexpress
But you would need to be ok with their eternal shipping delays…
Pontuação 0
if you have broken screen, yet LCD is good, I can refurbished it for you. This keeps original Apple LCD.
contact me thru ifixsmartphone.com
Pontuação 0
I can highly recommend
https://www.injuredgadgets.com
Just got a refurb screen from them, popped it in and everything works. Just a satisfied customer.
Pontuação 0
Adicionar a sua resposta
proffesir_snape será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 37
Ao todo: 5,599
