Ir para o conteúdo principal
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
41 Perguntas Visualizar todos
How to fix scratched screen on MiA2 .?
I fell over with mobile on my hand and it left some scratches,
How can I repair or need to replace the whole display itself.??
I do have a 1 year warranty for the Mobile, which doesn't cove any of this damage.
Still need to know the process of repair.
TIA
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
adithyaghaadimane  check this video to see how to replace the display. As for using it, yes you can if it only affected the glass. If you find that you are starting to have display or touch issues you will have to change it.
Esta resposta foi útil?
Pontuação 2
It depends
If you can use the phone with the scratches, then no problem you can use it
if you prefer not to have them there then you would have to replace the screen
Pontuação 1
Adicionar a sua resposta
adithyaghaadimane será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 381
