Ir para o conteúdo principal
The second generation of the Samsung Gear, a round smartwatch running Samsung's Tizen smartwatch OS. The Gear S2 was released in October 2015.
20 Perguntas Visualizar todos
The back cover keeps coming off
The back of my watch keeps falling off. Looks like it was held together with some sort of adhesive.
Esta é uma boa pergunta?
Pontuação 1
9 comentários
FWIW, the battery tutorial linked below doesn't mention any adhesive
Samsung Gear S2 Battery Replacement
Might want to closely examine the unit for broken locking tabs, maybe.
por
So the part I'm talking about is the part that is directly against the wrist, not after you open it to get to the battery. So if it falls off it exposes the gold part not the battery. It has a small window on it which is usually the sensor
por
@Jayne a Ahhh OK thanks for the update. Guess the sensor must be part of the charging system then, is that right? Being retired I haven't worn a watch in donkeys years now and so am not really up to date on the newer styled watches. Good luck with your investigations though. :-)
por
I have tried…seems like it needs some sort of adhesive glue to stay but not sure if I can just use regular gorilla glue
por
@propman thanks...so frustrating that they want to charge 70 dollars to replace the whole back but all I need is some glue...lol
por
Exibir mais 4 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
It appears to be a compression fitting. See if you can find someone with strong hands and thumbs to press it into place.
Esta resposta foi útil?
Pontuação 2
That worked! There was a notch where the dial was that I had to line up and then it took a lot of pressure around the outer edge of the metal back but I heard a few clicks as I pressed very hard around it.
Pontuação 0
Adicionar a sua resposta
Jayne a será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 4,454
