Ir para o conteúdo principal
Samsung Gear S2 Battery Replacement
O que você precisa
    1. Samsung Gear S2 Battery Replacement, Watch Strap: passo 1, imagem 1 %32 Samsung Gear S2 Battery Replacement, Watch Strap: passo 1, imagem 2 %32
      • Flip the watch over so that the face is down.
      • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
      • Remember to turn off the watch to avoid being shocked.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear S2 Battery Replacement: passo 2, imagem 1 %32 Samsung Gear S2 Battery Replacement: passo 2, imagem 2 %32
      • Using your finger, push forward on the release while pulling up on the strap.
      • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear S2 Battery Replacement: passo 3, imagem 1 %32 Samsung Gear S2 Battery Replacement: passo 3, imagem 2 %32
      • Repeat the procedure from step 2 for the other strap.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear S2 Battery Replacement, Back: passo 4, imagem 1 %32 Samsung Gear S2 Battery Replacement, Back: passo 4, imagem 2 %32
      • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
      • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear S2 Battery Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Gear S2 Battery Replacement, Motherboard: passo 5, imagem 2 %32
      • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear S2 Battery Replacement: passo 6, imagem 1 %32 Samsung Gear S2 Battery Replacement: passo 6, imagem 2 %32 Samsung Gear S2 Battery Replacement: passo 6, imagem 3 %32
      • Using a spudger, pry up the three cables.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear S2 Battery Replacement: passo 7, imagem 1 %32 Samsung Gear S2 Battery Replacement: passo 7, imagem 2 %32
      • Using the flat end of a spudger, pry up the motherboard.
      • Make sure the cable is fed through the hole to avoid damaging it.
      • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear S2 Battery Replacement, Battery: passo 8, imagem 1 %32 Samsung Gear S2 Battery Replacement, Battery: passo 8, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, lift the battery casing.
      • Make sure the cables are fed through their gaps to avoid damaging them.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear S2 Battery Replacement: passo 9, imagem 1 %32 Samsung Gear S2 Battery Replacement: passo 9, imagem 2 %32
      • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
      • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
      Pergunte ao FixBot
      Comentar
Conclusão
103 outras pessoas executaram este guia.
Jacob Baldwin
Membro desde: 02/20/17
3.459 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Membros
Autoria de 23 guias
39Comentários do guia
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - Responder Compartilhar
A reference to the battery part number would be great.
Harold Turner - Responder Compartilhar
Very good job and very easy
JEAN PIERRE - Responder Compartilhar
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 154
Ao todo: 162,164
