Ir para o conteúdo principal
Informações de reparo e resolução de problemas para tratores cortadores de grama da marca Craftsman.
mower wont move when started
My T150 mower is new this year. I got a skinny stick caught between the mower deck and mower. It appeared to be wrapped around a metal rod. After I dislodged the stick the mower started but will not move. I am a 62 yr old widow and have NO idea how to fix it. Any suggestions would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
My first thoughts are that it is the throttle pusher or the parking brake. Can you let me know if you can rev the engine, and if it is in neutral?
por
Adicionar um comentário
1 resposta
Broken or stripped gear in rear axel assembly, if it is not as simple as a broken belt. More expensive to fix than it's worth.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mary Helsel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 184
