Ir para o conteúdo principal
Repair guides and support for motorcycles manufactured by the German motor group, BMW.
17 Perguntas Visualizar todos
Metal in Oil after seize
After my 1970 BMW R50/5 seized, I took off the oil pan to find it had a great lot of ferrous metal pieces in it. The bike was in great up to date shape. Is there anything in my cycle that would supply such thin metal during a seize, or was this vandalism.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Disintegrated piston oil ring maybe?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@irnktn most likely will be that this comes from whichever part caused it to seize. This could be from broken piston rings to rod and main bearings. Your engine is do for a major rebuilt
Esta resposta foi útil?
Pontuação 2
Metal in your oil means broken internal parts.. If the engine seized then that would be a sign of engine failure.
Pontuação 0
Adicionar a sua resposta
Mustone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 73
