Aluminum body is becoming warped
I just noticed that my 2015 MacBook Pro’s top lid is becoming warped. Why I don’t know. The battery says it’s fine. I need to know what the repair is going to cost me.
Esta é uma boa pergunta?
Not sure what you are pointed issues is here:
The display cover: A loose hinge can cause the lid to shift a bit and sit a bit proud. At this point you likely only need to tighten the screws. This is a simple problem.
The uppercase frame: A common issue here is the computer is stored in a backpack that caused the system to twist when carried. This could be a set of books being inserted so when the backpack is carried cause excessive pressure. Removing the display and carefully twisting the frame might be all that’s needed. If severe you may need a new uppercase.
The bottom cover: The more common distortion is the battery is swelling up pressing on the cover so the system won’t sit flat on a desk. I would run Coconutbattery posting a snapshot of the apps window here so we can see. Its best not to use or charge the system as the battery could fully push out.
Be aware there is a battery recall on your system! Plug in your systems S/N here 15” MacBook Pro Battery Recall Program I would strongly recommend you get your system to either an Apple Store or authorized service center to have it replaced under this program.
If your system is not part of the recall you can replace the battery your self. Here’s the needed part MacBook Pro 15" Retina (Mid 2015) Battery and the guide Substituição da bateria do MacBook Pro 15" com tela Retina de meados de 2015.
If the cover is pushed up I do recommend you open the system up outside just in case as as soon as you release the pressure the battery could expand still more. If you can run the battery down so there is less power in the battery.
Esta resposta foi útil?
I have one of these come in on Saturday, Customer was having difficulty clicking on the trackpad but it would track just fine. Coconut Battery shoed the battery to be in good shape. After I took the first two screws out of the bottom case, if was immediately pushed up. After I got it open, ALL the calls were swollen. Luckily I had a new battery in stock and replaced it. Problem solved and happy customer.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 4,401
