Ir para o conteúdo principal
O Samsung Galaxy A3 (2017) é um smartphone intermediário da série Galaxy A. Foi apresentado pela Samsung em fevereiro de 2017, juntamente com o Samsung Galaxy A5 (2017) e o A7 (2017).
Using smd rework station
Hi,
I am quite new to mobile servicing. I want to use smd rework station. While doing so, there are much opportunities for the damage of nearby components . Are there any ways to avoid damaging such nearby components?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Yep, there two ways that I use to shield surrounding components of what you are heating up.
  • Apply Kapton (Yellow non-conductive) tape to surrounding components
  • Use thick metal objects that absorb heat well like a penny / coin (if needed)
Pre-heating the board to something like 80°C will make it easier to remove the component being heated.
Avoid using a small nozzle as they are prone to blowing surrounding components away for the heat gun and don’t heat components for too long when putting them on to the board.
For a lot of my re-work I use 380-480°C depending on the heat required, this will vary between hot air stations so might want to practice removing and putting back SMD components / BGA components on dead boards first.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
S.Kumar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 229
