Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
20 Perguntas Visualizar todos
Replacing screen for series 3 gps only
I have a series 3 gps only version 42 mm. Will a cellular version screen work for gps only? I ordered cellular screen by mistake?
Thanks,
Adi
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hello. Yes I can confirm that the cellular and GPS screen work together. I did it myself and the both worked on each other. The cellular screen appears to have an extra antenna or something like that from what I can see.
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thank you, Riley!
por
@rilextm did you have any issues with touch screen after replacing gps only with cellular screen?
por
@royaleagles No I didn’t at all. The screens worked perfectly normal.
por
@rilextm for some reason the touch sensor is not working....display is ON
por
Adicionar a sua resposta
aditya panshikar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 92
