Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Vibration doesnt work accept home button
Vibration is only working in home button feedback but not in other cases like the system wide haptic feedback or vibration on ringtone.
i severely broke my phone & had to change the casing by placing my motherboard onto another iphone 8 plus casing which was icloud locked.
After that I’m facing 4 problems
  1. Haptic feedback works only on home button (tried changing setting and restore iphone)
# No airpod prompt when I open the lid, cant connect it instantly, gets disconnected often
  1. low wifi range
  2. Most often only 2 bars in cellular network indicator.
  3. can anyone suggest me a fix?
  4. thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
  1. low wifi range
These two more then likely caused by incorrect assemble of the antennas
you need to back track on your work
iPhone 8 Plus Wi-Fi Diversity Antenna Flex
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks @edigitcom
And about taptic feedback?
por
Swap the vibrator over so its using the original.
Pontuação 0
Adicionar a sua resposta
Nazmul Hossain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 385
