Introduction
Use this guide to replace the small flex cable running from the Lightning connector flex to the logic board in the iPhone 8 Plus. Replacing it may resolve a number of connectivity issues.
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
One 1.4 mm screw
One 2.7 mm screw
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
Remove the three screws securing the L-shaped bracket next to the Taptic Engine:
One 1.3 mm Y000 screw
One 2.6 mm Phillips screw
One 3.5 mm Phillips screw
8 other people completed this guide.
4 Comments
My Cellular data connection keeps connecting and disconnecting consistently. I received a message “Could not activate cellular data network”'.
WiFi and Bluetooth work fine. Could this possibly fix my issue or is it more of motherboard issue?
Thank you if anyone can help. My phone is out of warranty
Same problem. Any solutions? Thank you.
So I broke the plug in on the logic board where you plug in for WiFi, is that fixable . Oh I broke the plug in for the LED light also
This is cellular antenna btw.
