Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
Top part of screen not reponsive after Screen Replacement
I just got my IPhone X screen replaced after I cracked it, but did not realise that the top part of the screen is unresponsive. The rest of the screen is working fine, but I feel like it has to do with something very simple. Anyone know?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Did you replace the screen yourself? Or did you give it to a repair shop or apple? If you did the latter, then send it back to them as they have given you a defective screen.
por
Adicionar um comentário
1 resposta
Solução escolhida
I would perform a soft reset - tap volume up, tap volume down, then long press power button until you see the apple symbol, if that does not work, i would open the device, make sure the connectors are seated properly. If they are, It is in my opinion you have a defective display and it would require replacement. If your replacement display has the same issues, there are a number of iPhone X models that do have touch screen issues but typically you will see a green line running vertically along the display if that’s the case. My guess is defective display but i would try those troubleshooting steps first.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Well when I bought the phone almost 2 years ago, I got it insured with Asurion, and they keep telling me that they have to replace the device.
1. I want to upgrade to the new iPhone coming out.
2. I think it the connectors is not connected properly, but stupid insurance does not want to try and fix it.
3. I don’t have the tools to open the phone.
por
Adicionar a sua resposta
Jordan Gonsalves será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 38
Duração total: 5,185
