Ir para o conteúdo principal
Installation of backlight sheets for LCD
Hi
I know that the bottom-most layer (white, not transparent) can be installed very simply. But the second illuminating layer (Layer 2) should be attached back to back to the origin of light on the bottom of the display assembly. Looks like I should use adhesives to do so. What is the right method of attaching the Layer 2 ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Misha,
Layer 2 is a acryl (or acryl-like) layer. The top pushes against the edge of the frame where the LCD rests on. The bottom pushes against the backlight bar.
You can't simply put this layer down and move it into place like all other 4 layers. This acryl panel needs to be bent vertically. I recommend bending, pushing the top edge on the frame and then the bottom edgea gainst the backlight.
Hope that answers your question. But I have a feeling you didn't mean the acryl panel layer although you refered to by mentioning “layer 2” which is the acryl panel.
Edit: No, the second layer (the acryl panel) does not have any adhesive.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thank you for sharing the right method. It is very helpful. Yes, I mean the acryl panel layer. But the question was... Do I need any adhesive to attach it? Because cheap Chinese replacement parts on the market usually do not have it. But the original acryl layer does have it - a very thin and narrow strip of transparent adhesive on the bottom edge.
por
Honestly Misha, I do not remember the acryl panel having any adhesive and I just replaced on 2 hours ago. The first layer is the only layer that has adhesive (and it's on the bottom).
por
@capacitor HI I had 2 sets of sheets laying on the desk and they fell onto the floor and have got all mixed up.... yay.... One set from a 2014 and the other from a 2017 Air (Both A1466). what order do thy go in starting from the one that goes 1st into the top shell? I have a white one with a black border, One with 2 tabs either side, transparent with black edge, another silver.... a mess.... help. @oldturkey03 & @danj if your around?
To make things worse, the top shell from the 2014 & 2017 maybe have been mixed up, is the backlight flex the same on both? As also the backlight flex on the 2017 has broken.... I guess if the flex cable has broken away from the top shell it is trashed also?
por
Adicionar a sua resposta
Misha Krasnorutsky será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 62
Ao todo: 770
