Pressing L2 trigger also register pressing up
Hello, so my issue is that if I fully press the L2 trigger on my ps4 controller , It also act like I'm pressing up as well. It doesn't seem to do that though if I just lightly press. I tried resyncing it and even open up the controller to remove any dust, but the issue is still there trying both options. Anyone know what could be the issue?
Esta é uma boa pergunta?
9 comentários
When i press l2 i look up
por KissMyAimbotBro Compartilhar
Did anyone find a solution? I also have this problem where I press L2 on fortnite and my character/camera looks upwards.
por Elijah Silvas Compartilhar
Yeah me too it's really annoying ima try to reset the controller.
por Itskelyan23 ' Compartilhar
I read on another thread that either resetting the controller or dabbing a little bit of oil at the base of the stick will do the trick i had the same issue and with the reset, i’m all good
por djerrazuriz Compartilhar
you can fix this with a little bit of electric tape.. as i had this issue with the dualshock 3.. just locate the ribbon that connects every button and trigger and insert a little piece of electric tape to make a better contact https://www.ebay.es/itm/Sony-PS4-control...
por Tortita Compartilhar
Exibir mais 4 comentários
