Ir para o conteúdo principal
Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
468 Perguntas Visualizar todos
Bottom of screen yellowish than top
Hello. Recently I bought brand new XR and it works perfect but I have one problem, the bottom of screen looks more yellowish than the top, what is the reason of that problem and how to fix it? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
That usually happens after lcds are very old.if you replace it your problem will be solved.
Esta resposta foi útil?
Pontuação 0
if you just bought it new you should probably just return it for an exchange really. if you open the device to fix it they may not take it back
not really a “repair” solution I know. as far as what’s going on, as Owen said, it’s probably just an issue with the age of the LCD.
Pontuação 0
Adicionar a sua resposta
Fado the don será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 143
