Ir para o conteúdo principal
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
Where is the fuse for horn and drivers seat?
Horn is not working
Drivers seat won't lower down in the front. Also won't move up or down. The back adjusts. Lumbar works and back part of seat will lower.
When I try the front and up and down it clicks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
novatay1 those things are not related by a fuse. the horn fuse is in the fuse box under the hood besides the battery. Fuse #18 is the horn fuse. You also want to check the horn relay and the horns. With all the adjustments you can do on your seat is is not a fuse that is a fault here. you said that “When I try the front and up and down it clicks “ so I would check the motor for the seat. The clicking is most likely the relay. You need a multimeter to test this. Here are the chapters that will help you with the diagnostics and repair Power SeatsHorn
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
novatay1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 1,296
