Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
How much would it cost to change the keyboard layout
How much will it cost to change my keyboard from French to English?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
On that model keyboard is integrated in the upper case. As it’s considered vintage you won’t find a new replacement, thus you’ll have to revert to second hand market where you’ll find different spares conditions and prices. Replacement isn’t exactly easy, you’ll have to remove quite a bit of screws, but it can be done with some patience..here’s a guide to help you with the task:
MacBook Core 2 Duo Upper Case Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Leah será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 329
