Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Perguntas Visualizar todos
How to retrieve data on SSD part of a fusion drive?
Hello everyone
Am I able to extract the SSD part of the Fusion Drive (I believe is attached to the logic board)? To retrieve whatever data is on it by purchasing an external adapter / case and connecting it to another iMac? My logic board is completely shot so I need to retrieve all the data inside the SSD
Thank You in advanced
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The blade SSD in a Fustion Drive set is quite small and is setup as a cache drive Vs a data drive. Basically, the more highly access files, the OS and mostly apps are held within it. So salvaging it won’t offer that much that you can’t recover during a re-install of your OS and apps.
Here’s the guide to get to it iMac Intel 27" Retina 5K Display Blade SSD Replacement and OWC does offer a case so you can install your SSD into.
But before we go down this path how about telling what’s happened. And what you are hoping to recover.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
li lok será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 67
