Ir para o conteúdo principal
Informações de reparo e desmontagem do mouse wireless Logitech M310. Este mouse é vendido separadamente ou como parte do conjunto MK540. Identificável pelo número de modelo M-R0014.
Left mouse button does not drag and drop
My m310 left mouse button does not drag and drop properly. I can grab and start to drag and then it lets go and the pointer continues on. Right side works fine.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Maybe the following will be of use:
https://larryprevost.com/2017/03/logitec...
Esta resposta foi útil?
Pontuação 1
Apparently this is a common issue with these. Mine lasted about 8 yrs before the left switch started going flaky. I would have fixed with a new micro switch but the above guide from “prop man” gives a link to the switches that says “not available” currently. More supply chain woes I guess. :( I Bought a new one for $18. Next time I will cannabilize the right switch from this old one and save my money. I have just recently started doing a lot of data entry into genealogy web sites that must have spelled the end for it.
Pontuação 1
Adicionar a sua resposta
Malon Metz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 1,104
