Ir para o conteúdo principal
Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
290 Perguntas Visualizar todos
starter start correctly - put in gear all OK - put back on park or neu
turn the key - car start - starter still on and turning - put in gear and starter normal - put back in park and starter spin (key-neutral safety -starter?
Update (08/12/2019)
@fixnpop59
Ok, gmc sonoma 1995 4.3lt.
I'm in park - I turn the key to start - the engine crank and run - the starter is still spinning, just sinning - bendix not engaged - put the transmission in gear, the starter stop - put back in park he starter spinning again
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hey Roland. To be clear- are you saying the starter on your engine continues to try and start the engine after the engine is running? And that if you then shift from "park" into "drive" the starter no longer keeps turning? Wow.
With your reply, please tell us specifics about your vehicle, also.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey Roland. Thanks for the clarification.
Found something that could be helpful to you. Simply do an online search for:
ricksfreeautorepairadvice.com\starter-runs-continuously
Hope this might help. Good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Roland Ducommun será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 38
