Ir para o conteúdo principal
Um smartphone Android da Samsung para o mercado asiático, conhecido por vários números de modelo, lançado em dezembro de 2014. Inclui os modelos SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
Back button not working
Back button does not show light and not responding to touch. Recent tab key pad is working with light on although my screen is broken but working perfectly.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like it needs a new Charging flex as this is where the Back&Recent buttons are located on this model.
If you feel you are competent enough you can follow the guide below and attempt it yourself. Although this is risky as the LCD is held on with fairly strong adhesive and since its already cracked there is a high chance of completely breaking it upon removal.
Substituição da placa de carregamento USB do Samsung Galaxy A5
Other than that you will likely have to take it to a local repair shop where they should be able to complete this repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Abiola Seyi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,715
