Ir para o conteúdo principal
A TI-89 Titanium é uma calculadora gráfica desenvolvida pela Texas Instruments (TI) e lançada em 2004. As calculadoras TI-89 incluem um sistema de álgebra computacional que permite a manipulação simbólica de expressões algébricas.
missing horizontal pixels on display screen
I have two missing horizontal lines of pixels. The first is just below the tool bar and the second is almost half way down the screen. I ran the self test for the calculator and confirmed that the lines were missing. Is this a hardware problem or software problem. How can I determine which it is. If it is a software problem will a reset fix it without removing the factory installed programs. But if it is a hardware problem would this be an easy fix.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi this sounds like a hardware problem. Unfortunately, unlike the TI 83 and TI 84 lineup, the TI 89 ti doesn’t have a standard ribbon cable you can fix, instead TI attached everything to one piece making it nearly impossible to fix yourself. Even the most skilled calculator enthusiasts I know haven’t been able to repair a TI 89 ti display. :(
I’m sorry I wasn’t able to help you repair it, however if you have any other questions I’ll be happy to answer them.
Esta resposta foi útil?
Pontuação 1
https://www.cemetech.net/forum/viewtopic...
Pontuação 0
Adicionar a sua resposta
Lawrence Dunbar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 2,026
