Ir para o conteúdo principal
Question regarding USB C charging port
Recently, my IPad Pro’s USB C port stop working, and apple is charging me 650$ in replacement price.
I look through the shop, but don’t seem to be able to find a replacement for the USB C port. Can someone help me, this is going to the first time I’m doing a repair on my own device.
Esta é uma boa pergunta?
Pontuação 4
2 comentários
Where you using an Apple charger and the cable that came with it?
Did you physically damage the socket?
por
@danj I have only been using the Apple charger / adapter that came with my Ipad Pro, nothing else.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Most likely corrsion in the usb c port… happened to me, my solution is to open the ipad, take out the usb c part, clean it, place it back, then it works fine.
though i cracked the screen in the process
Esta resposta foi útil?
Pontuação 1
Here’s the needed part iPad Pro 11" and 12.9" (2018/2020) USB-C Port
We don’t have a proper guide but this should help Teardown do iPad Pro 12.9" 4ª Geração
Imagem de Replace the USB-C Port and its cable for an iPad Pro 11" 2018 or 2020 model or 12.9" 2018 or 2020 model iPad Pro.
Produto
$23.99
Pontuação 1
Adicionar a sua resposta
oneye man será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 1,152
