Ir para o conteúdo principal
Repair guides and support for televisions manufactured by Sony.
20 Perguntas Visualizar todos
TV keeps rebooting continuously.
Hello,
SONY XBR-65X900C keeps rebooting continuously.
I did unplug all the cables, swapped power outlets, kept it unplugged for more then a day, but still it reboots. I cannot access the menu to do a factory restore because it reboots too fast.
Thank you!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
@mk_sco check something out for us. Remove the back of your TV and disconnect the power board from the main board. See if your backlight turns on and see if it stays on or if your TV continues cycling. This could be a Main board issue as well as a power board issue (less likely) Once you have your back removed post some good pictures of your boards and interconnect wiring with your question. That way we can see what you see.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hello,
I will check and upload the pictures.
Thank you!
por
Adicionar a sua resposta
Alex T será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 6,024
