How to clear the 2 vertical lines on the screen
My TV screen has two vertical lines on both sides of the screen ,making it smaller than normal.
Esta é uma boa pergunta?
HUMPHREY MARODZA first let’s clarify that you do have a LG 17LX1R. Then you need to make sure that your aspect ratio is set properly. Go through your TV menu and check on that. If all of that checks out okay it could be an issue with the main board
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 281
