Why can’t I press the bluetooth button?
i’m able to power it on when i plug it in and when i hold down the bluetooth button and power button it turns off . how do i get the bluetooth capability back on?
Esta é uma boa pergunta?
Hi,
What happens after you turn on the speaker by just pressing the power button, is the BT light on or flashing?
If the blue BT light is not on just press and hold the BT button only until the BT blue light starts flashing.
Once it does should should be able to pair it with your device.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 4,000
2 comentários
Hi
I have the same issue. How did you resolve it?
Thank you.
por Yuriy
I just had same problem and I held the negative (-) and Bluetooth buttons to restart it
por Hot Boy Kerosene
